Timeline is not creating the in-between frames
Hi
I am new to Maya. I am trying to perform the walk cycle to a rig. I use 25 frames. Although I created the initial rig in frame 1 then I moved to 7 and then to 13 and finally to 19 before the last frame pose in 25th.
From 1 - 19 frames Maya correctly reproduces the in-between frames but from 19-25 I am not getting any in-between frames. It goes abruptly from one pose to another with no coherence.
How can I fix it?
trs_andre
Hi!
Can you add your scene file so we can check?
André Moreira
Game Developer / Technical Artist
LinkedIn
Thank you for your feedback. Before I attach the scene file, let me tell you that I created the frames using a Stepped in Animation preference settings. But the 19th frame pose is the same until the 24th and suddenly the 25th frame change abruptly position. How can I convert the frames from 19-25 to be Spline or Clamped?
trs_andre
You should be able to do that by selecting the keys on your animated object in the Graph Editor and then choosing clamped or other option in the window upper buttons!
André Moreira
LinkedIn
