Rigging issue
Rigging issue
Rigging issue
Hello  ,i need help ,when Rigging the hand I set the curl attribute to 10 and the compoundCtrl's rotation Z to 90° but the palm Geo flipped what might be wrong?
jarombrand
The palm geo flipped, or it rotated up 90 degrees? It's really hard to tell what's going on with only the provided screenshot. What is driving the wrist joint?
Yeah It rotated 90° whereas  according to the tutorial am using
https://youtu.be/X82V9i0ifmk @3:25 the wrist/palm doesn't rotate
jarombrand
I would start by graphing the inputs of the wrist joint to see what is driving it. Open the Node Editor, select the wrist joint and click the "input connections" button:
If you are still not sure what's causing it, share a screen shot of your node editor.
