Announcements
Problem with graphic card NVIDIA
I've graphic card NVIDIA GeForce GTX 745 on DELL OPTIPLEX 7040 , and I can't start Maya , first time after change to new my graphic card , Maya starts correctly but next times was the same like before .
On screen We can see my error . I really need to fix this for student lessons in PJATK.
I will be glad for Your response ,
Best regards,
Monika Lachowicz PJATK
francesco.torchia
Hi Monika @Anonymous! Welcome to the community!
The error message displayed in the screenshot you attached is generally a sign of uncertified or out-of-date hardware or hardware drivers.
The graphics card NVIDIA GeForce GTX 745  is not listed among Maya Certified Hardware, so it is possible that the card is not able to run the application. I would suggest to install the most updated drivers for this card. (Here you can find the drivers for Windows 10).
If the drivers update should not solve the issue, I would consider to use a different graphics card, chosen from the list mentioned before.
Francesco Torchia
Technical Support Specialist – M&E (3ds Max, Maya)
francesco.torchia
I hope you are fine. I just wanted to follow up and ask if my previous message helped to solve your issue.
If so, please click Accept Solution on the post, so others in the community can find it easily.
Francesco Torchia
