Announcements
Parent Constraint Result Joint to Twist Joint, Not Translating with Rotation?
sweetpea09234
sweetpea09234
So I am Following this Tutorial.https://www.youtube.com/watch?v=hjl8we7VVK0&list=PL8hZ6hQCGHMXKqaX9Og4Ow52jsU_Y5veH&index=22
I have an IK,FK, and Result Joint all sorted. So I create a basic spline twist set up for the arm, and its working, except for when I translate the arm. I can Rotate the arm via either IK/FK controller for the arm, and the twist joints will rotate beautifully, But they wont translate with the rest of the result arm. I used a parent contraint with should copy both translation and rotation right? I looked at the version they provided, and everything from the Advanced Twist Controls to the Node Editor looked perfect. So now I can't fathom as to why it's not working, I've redone this twice so it has to be some sort of mistake Im making but can't catch?
mcw0
Where are your result joints in the left image?  Do the result joints react at all when you rotate the twist joints?
