Announcements
Parent Constraint issues and fk handle issue
anjmariehays
Observer Observer
anjmariehays
Observer
Observer
Hello! I am struggling with an ik/fk issue with a hand remaining planted on a moving object as well as a parent constraint with the hand carrying the character's ik/fk problem. It's like a king kong scenario and so far and it's looking messy. If anyone can help, that would be great!
The rig system I'm using is advanced skeleton 5 if anyone needs to know!
Kahylan
Hi!
I can't see your hierachy, but it seems that you have constraints going in both directions. Meaning that the Hand is Following the Fairy while the Fairy is also following the hand.
This is what is called a cyclic connection and can lead to very messy results.
Generally speaking, you want to have the lighter object follow the heavier one in situations like this, this makes it easiert to deal with the mass and inertia of the animation.
So in this case I would constraint the Fairies Root control to the right hand control and then animate everything using the hand control.
I hope it helps!
