Moving controller with a controller in a smooth transition
Richardd013
Richardd013
Hello Im new to rigging so i just downloaded a free model made by Carlos Contreras
today im breaking up some Joints and handle inside the maya scene for study purpose, and i just found out a new things i haven't seen before. How to control a controller ?
below i attached some images i captured from the maya scene
so as you can see when i move a curve controller the other curve controllers bellow follow it with a smooth transition on them.
hamsterHamster
The direct answer is: by layering the controls.
I am not familiar with this rig, so I will reverse-engineer it in my head.
Let's assume, all of those small ball-shape beige controllers are from the level #1, those control fine details (mouth shape and antennae smaller circles also are from this layer). Click one of those controllers, open the Outliner, press F. Explore the node hierarchy up and down.
Most likely, you will notice each of those is parented to some auxiliary object (group/locator) to zero out transforms, which in turn is parented to some SplineIK chain, that is cluster-deformed by the larger green curve, which belongs to a level #2 controls, that control larger mesh volumes (red antennae rings, green tail ball etc are from this layer too). So, when you lift the green curve, it makes bell shape for that underlying curve, that transforms the joints to which the beige controls are parented/constrained; same joints bend the main body mass.
The #3 level are yellow curves, except the outer ring, that allow to do rough body transition through the scene.
The #4 level is the outer yellow ring, that has master controls and is meant for positioning the character in the scene.
The level numbering can be reveresed and even more subdivided, it just was more easier to explain starting from the minute, toward the general.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
Richardd013
thx for answering but its kinda too difficult for me to try out by myself, i didnt get the idea 100percent. wish someone could make a simple tutorial of this. i attached the maya file below
