Announcements
Mixamo / Trax editor / Time editor / Human Ik... what is the process ?
moiamy
moiamy
Hello everyone
I would like to share with you my experience.
I have downloaded 4 animations from Mixamo, and the purpose was to blend them.
1. Import each FBX in Maya / Select joint (hierarchy) / Trax -> create animation clip / select animation clip / Trax -> export animation clip Maya ASCII format
2. With same T-pose Character import all animation clips previously saved
Problem was : The blend animation between two clips was not working.
I thought it was because I needed to rig with humanIK.
3 I did that part, but when I try to apply control rig to the source, animations from Trax were not working anymore.
So I figure I need to go though the time editor (wich was supposed to replace trax) and try to import animation clip to y rigged character, but here is the message :with .ma files
// Error: line 0: Unable to create clip because 'C:/Users/B/Documents/maya/projects/Yuka/clips/walking.ma' content does not match any objects from the scene //
With .mb files it loads inside Time editor through content browser, but doesn't fit the animation (see below)
So I would like to get your advice about this processs
Fransua
moiamy
Solution : I have imported my fbx one by one inside Maya and Time Editor. Export selected from Time Editor.
From a T-pose I have imported all these animation inside Maya/Time Editor from Content Browser.
(Still don't understand if I need or not to do the Human IK process)
