Maya freezes whenever I key a controller on a rig
kurtvintiz
Observer Observer
kurtvintiz
Observer
Observer
I've just recently built a new pc so I can do my animation to a high standard, here are the specs;
core i7 12700KF
RX6600
64GB DDR4 Ram
MSI B760-P Wifi DDR4 Motherboard
2 TB NVME M.2 storage
So I've had this problem with my first pc, which was running 16gb of ram and a core i5 10400
whenever i would load in a rig, most of the time when I key a controller, the application would freeze for sometimes seconds, minutes, or even just crash altogether. I've enabled XMP profile for my ram, but when i go onto task manager when Maya is running, its only using 10-20 percent of the CPU and about 20-30 percent of the RAM, but when I key something, CPU skyrockets to 60s or 50s, so I don't know why its lagging or freezing. I tried switching to a different rig, they all had the same issue, and it only ever happened if i tried to move a controller and key it. can someone help me with this please?
jmreinhart
Is this occuring when you are parallel and DG evaluation?
What about if GPU override is on or off?
