Maya 2022 Graph Editor Bug showing blank.
y25mstudios
Message 1 of 17
y25mstudios
Hi, I recently installed Maya 2022 and I am experiencing many issues regarding animation,
the biggest problem is dealing with graph editor.
I tried to open files done with Maya 2019 or earlier version, animation was there but the graph editor was broken as above. Also even creating a new scene with referencing the character had broken graph editor that I am not able to use Maya 2022 for animating at the moment.
I blew up the preferences and started fresh on this version of Maya but it did not fix the issue.
I am using the latest Geforce Gaming driver and the latest version of Windows 10 up to date.
When I open Maya 2019 these scenes will work as normal and show all curves in the the graph editor.
Replies (16)
Message 2 of 17
marie-jeanne_leduc
Could you please try to tear off the graph editor panel by selecting "Panels > Tear off" ?
Please let me know if this helps with the display issue you are seeing.
Marie-Jeanne
Marie-Jeanne Leduc
Senior QA Analyst
Message 3 of 17
y25mstudios
@marie-jeanne_leduc
It worked!
It is interesting that tear off the graph editor fixes the problem.
However, every time I open up need to tear off the graph editor and bring back my work UI to display the graph editor properly.
Will there be a permanent solution for it as updates deploy in the near future for a bug fix?
Thank you for the workaround!
Message 4 of 17
marie-jeanne_leduc
Thank you for reporting this issue and for confirming the workaround.
We can reproduce it and this bug has been logged:
MAYA-110408 Graph Editor : Curves are not displayed when opened through panel menu
It has been raised to the development team and we will keep you posted.
Marie-Jeanne
Marie-Jeanne Leduc
Senior QA Analyst
Message 5 of 17
rebelanimation
Community Visitor
Community Visitor
Has this been resolved? This seriously hinders and reduces workflow options. A torn off graph editor is not the best option. Please advise.
Message 6 of 17
marie-jeanne_leduc
We are working on a fix (not sure exactly which release the fix will be included in yet).
We will update you when we know more.
Marie-Jeanne
Marie-Jeanne Leduc
Senior QA Analyst
Message 7 of 17
Just chiming in that this fix didn't work for me, tried after reinstalling Maya 2022 multiple times and no luck.
Hope the fix comes soon.
Thanks.
Message 8 of 17
Hi
I cant see the curves on a graph editor no matter what I'm doing and there is also no "panels" menu for the graph editor on 2022.
Curves are not visible neither for the old projects neither for the new ones
Please assist
Message 9 of 17
y25mstudios
I just tried installing the 2022 latest update, but the graph editor issues persist.
Graphs are only visible with the previous workaround.
Message 10 of 17
this issue of graph editor display is not a tiny thing...As animator and teacher it will be very complicated too start learning interpolation into maya without this fixed.
Thanks to notify when do you know  the fixing update date ( i hope soon cause the school is opening at the end of september).
Message 11 of 17
marie-jeanne_leduc
This issue is fixed in Maya 2022 Update 2 release.
Please try in that release and let me know if this resolves the issue for you.
Marie-Jeanne
Marie-Jeanne Leduc
Senior QA Analyst
Message 12 of 17
aysen.ozgur
Observer
Observer
Hi.
I'm having the same problem with graph editor. I update maya to 2022.3 but it didn't fix. can You help me about it?
PS: I try the tear off metod but it just works for one select every time i select a curb i have to do tear off again
Message 13 of 17
movepidgeon
Community Visitor
Community Visitor
I'm having the same issue with a fresh install of Maya 2022 - the ideal setup is a stacked graph editor, this bug was reported originally in April, it's been almost 8 months without a fix?
Message 14 of 17
arcon76
Hi guys - I've had some issues with the graph editor but not this one... Have you tried installing the nvidia Studio driver instead of the Game Ready driver?
Message 15 of 17
hannahmator
I'm having the same problem today, in August 2023. Is there a fix for this yet?
Message 16 of 17
ls100s
i too am having a massive problem with this. nothing i have tried works. i upgraded from Maya 2021 which worked beautifully. i have been reaading that this is a HUGE problem with Maya 2022. i have all the newest updates and everything too. i am doing this for a class and did not have to pay for my one year subscription. i was going to pay for it after my year is up but now i do not think that i will be. i have been reachign out to tech support for weeks to try to resolve this problem to no avail. tech needs to up their game and actually provide me with a solution that works. i am not trying to be grouchy or rude, but this needs to be fixed or Au
Message 17 of 17
ls100s
*Or Autodesk will be losing a loyal customer
