locators + Joints + PathConstraint
dg3duy
Message 1 of 9
dg3duy
I have 2 splines in scene, in each of these splines a locator with path constraint runs through it.
What joins each one of the locators is a joint, what I do not know how to solve is that the joint does not turn unexpectedly as I show in the image, since the locators guide are not rotating, therefore I do not know the behavior of turns of the joint.
Replies (8)
Message 2 of 9
Kahylan
Hi!
Pathconstraints are really wonky when it comes to things where the object needs to be turned upside down.
Since you are doint this on a ribbon anyways, why not use a UV-pin constraint from the ribbon to the joints instead?
Message 3 of 9
dg3duy
@Kahylan It looks interesting and a way to try what you tell me, but unfortunately these are my first steps in maya in the area of path and joints, it is the first thing I really do.
You can make a simple example of what you mention, this sentence leaves me totally baffled. “UV-pin constraint from the ribbon to the joints”.
Message 4 of 9
dg3duy
@Kahylan I would love to see an example of what you mentioned, I still don't know how to solve the problem and you mentioned a way forward.
Greetings
Message 5 of 9
Kahylan
Sorry for the late response. I realised that I couldn't explaint the whole process via text very well and decided to create a video to show you. But my Maya Lisence had just expired and getting a new one took longer than I expected, since I changed the place I teach since the last time I renewed my lisence.
You probably already solved this problem by now. But in case you haven't, here is the video on what I meant.
https://youtu.be/UAIpAME8N84
Once again, sorry for the late reply, the timing was a bit unfortunate
I hope it helps
Message 6 of 9
dg3duy
@Kahylan It is exactly what I was looking for. I exploded with happiness when I saw the final result. I can't thank you enough, I was still looking for a way to solve it and you came at the right time! You are a total genius.
Message 7 of 9
dg3duy
@Kahylan
uv pin.gifa problem arose, maybe it is related to the version of maya I am using at the moment, I am using 2020.4
when applying constrain uv pin I don't see it appear after applying the options in the editor attribute named offset parent matrix.
I select the polygonal object and then each joint and apply uv pin constraint, I look inside each joint and no offset parent matrix is shown
Message 8 of 9
dg3duy
It's working perfect, I don't see the offset panel that you can see in the video but it's working perfectly! in Maya 2024
Message 9 of 9
Kahylan
I'm not sure if they moved the panel for the offset parent matrix in 2024, I'm still on maya 2022.4.
But I'm glad to hear that everything is working 🙂
