Knee Pole Vector and Root controller Issue
PJD1990
Message 1 of 10
PJD1990
Hey guys, I'm having an issue with a simple rig I created in maya 2018. I set up a Pole Vector controller to control the knees on my character's leg joints. The Pole Vector controls the knee joint direction fine. I have a root controller for the entire rig that all the controllers on my rig a parented to in my heirarchy. My knee pole vector controller is parented to my foot controller and my foot controller is parented to the root controller. When I rotate the root controller the Knee Pole vector, even though it follows the root controller fine, it affects the knees rotation. So if I wanted to rotate the character to face a different direction, the knees would not move along with the root controller.
I'm not sure how to ask this, but how do I get the Pole Vector to only affect the Knee direction when I use the Pole Vector Controller directly and for the knee direction to not be affected by the Pole Vector Controller when I rotate the Root Controller?
 Here is a gif to help see what I am saying.
Replies (9)
Message 2 of 10
Hey @PJD1990
Would you be able to attach the rig file to check out? thanks!!
____________________
Daniel López de Medrano
Remote Character Rigger
*14+ hour Rigging Course*
Message 3 of 10
PJD1990
No problem. The file is attached to this message.
Message 4 of 10
Hey @PJD1990
I tried attaching the file, but wasn't able to! Send me. your email through here or through private messaging and I'll send you the file your way and explain what was wrong! (:
Message 5 of 10
dinofiguera
Did you already fix this?
I was curious about it.
Cheers,
D
Message 6 of 10
PJD1990
Not yet, once I get the email from @Anonymous I will post solution on here.
Message 7 of 10
Hey @PJD1990
I'm so sorry, I thought I had it solved but it still gave the same error as before.
Its something to do with the IK setup... busy at the moment, but I will try again for about an hour tomorrow to see if I can work it out for you!! (:
Super sorry for the delay in getting it right, just been super busy.
Message 8 of 10
dinofiguera
I was actually asking you to post it so I could have a look. Maybe I can help you to find the problem.
Message 9 of 10
@PJD1990
Got it! Quite tricky to understand what was wrong, but now that I solved it, it genuinely makes perfect sense. I just never had to rig something like this before myself.
The simple answer is you can't have one control serving as a pole vector to 2 IK's, thats whats giving you the awkward rotations when moving your character entirely around.
I deleted both IK's with their constraints as you'll see in the video. Created them again, made 2 controls as pole vector controls and I made sure to align them straight with the joints, thats very important when creating a pole vector constraint!
I will attach the rig file here and the video showing what I did in detail as well! (:
Message 10 of 10
PJD1990
Wow, see, I knew it was some some small thing I was missing that I just couldn't sort out. Thanks alot for spotting that because I would never have found it lol. Thanks again man you didn't have to do it but I am happy you did and this will help for my next rig.
