Keyframe not working
Message 1 of 9
Whenever I'm trying to animate something by basic keyframing, a new problem appears, and the attribute which I'm keyframing, turns pale pink instead of red, to indicate keyframes and it doesn't animate. Please help me!
Replies (8)
Message 2 of 9
gautham.chandran47
Try following things,
• Deleting the maya folder from the document folder. It will reset maya to its original preference.
• Try changing the evaluation mode to DG.
• Try changing the render engine to DX11
Goutham Chandran
Cinematic Animator | Rockstar Games
Linkedin | Instagram | Facebook
Message 3 of 9
Thanks for the help, but I've Got It, it was a stupid mistake. The scene time warp was enabled when I opened the particular scene, and I didn't know that, hence the problem. Everything was okay when I removed the time warp.
Thanks again for the reply.
Message 4 of 9
how exactly did you turn off the time warp?
Message 5 of 9
SOMEONE HEL-[ PLEASE I HAVE AN ASSINGMENT IN 20 HOURS PLEASE
Message 6 of 9
janusscientes
[Animation] Key->Scene Time Warp and then you untick Enable Scene Time Warp
Message 7 of 9
jibinjolly.20
Community Visitor
Community Visitor
Bro I have been trying to do multiple things to fix the issue but this is what finally did it! Thank you so much!!! I can't believe it was a preferences issue!
Message 8 of 9
steve.herridge
Keyframes not updating.
DG fixes some keyframes, but not others.
Maya crashes when scrubbing through timeline.
Message 9 of 9
townsendkenzie
That's true that happened to me recently. I had extra keyframes in the rig I found them in the graph editor.
