keays in graph editor disappear
xatori
Message 1 of 1
xatori
lastly I have problems with my Maya versions.
I tried on version 2015, 2016, 2017 with the same result: if I key an object in time slider and there is only one key I can't select it in graph editor.
The same pays if I key the object on another time on time slider but I don't change the value I can't select it either. When I open graph editor I can see the keys but when I try to select them they disappear. I have to move with the object in the scene so I change value first and then I can select it in graph editor. Not before.
I also have problem with the graph editor keeping auto-framing my keys. I have to press F to frame the selection every time I select a key in graph editor. I'm serching through interenet for couple of weeks already but I didn't find any solution. I tried in preferences of Maya 2017 switch off 'auto frame' - it doesn't have any impact on it I also reset all preferences to dafault, with the same result.
On my PC I have installed Nvidia GeForce 900GTX I also have a notebook with Quadro K5100M where no such problems occur. I tried to reinstal GPU drivers several times switching to older and newest but with no luck.
I don't know what else to try, plase hela pe anyhow.
Thank you in advance!
Jana Satoriova
Replies (0)
