I want left hand to follow right hand
tafadzwamucheke
tafadzwamucheke
Please Help,I want the left hand to follow the gun.The gun is parented to the right hand.I want the left hand to follow where the right hand goes with the gun.The video shows the problem I'm havingg.JPG
Accepted solutions (3)
dinofiguera
Hello.
If you are using IK, then you should parent constraint the second arm to the first arm.
the ideal solution is to have a free parent on top of your arm control.
This way you can constrain this parent node so that your main hand control is still free to be keyframed.
If your arm control does not have a free parent, you can still directly parent constraint it,
but then you have to switch on and off the parent blend attribute, in order to switch the constraint effect on and off.
I hope my screencast will help.
Cheers,
D
dinofiguera
Sorry I noticed the mouse pointer is not working correctly in my screencast,
I must have done something wrong, let me know if it is not comprehensible for you.
Cheers
D
tafadzwamucheke
I really don't know how to thank you.Thank you so much it worked.
