HumanIK Rotation Problem with Rig's Arms
Whenever I try to test my rig using mocap data, the arms act like they are being rotated wrong. I tried multiple times to make sure the definitions are set correctly within HumanIK. It works on any other rig, but not mine. I can't seem to figure out what I did wrong. Anyone have any suggestions on what I should do?
Videos are attached to see my problem.
Here is the skeleton that is broken. If you try and map it up with HumanIK and use mocap data, you'll see how broken it is.
