Announcements
How to unparent shape node from a joint
jhonatan.chambi.capia
Hello everyone i have parenting a nurbs control in a joint with this line code: parent -r -s
how to split up in two independet objects? i mean separate them! Thank you so musch for your help greetings from Machu Picchu - Peru
i want to separate themi want to separate them
rajasekaransurjen
Hi.
Press "Shift+P" to exclude the selected object from the Parent group.
I do it, but that method doesn't work my friend 😞
 Any idea 🙂
stephenkmann
if you want that curve Shape node to exist on it's own, it needs another Transform node to be parented under.
Create an empty group ( or null)
and then use parent -r -shape from that curve Shape node to the empty group
hth
-=s
oh man, that's really work!! thanks for your help sensei 🙂
