Graph editor 'working range' jumping back and forth
malouise
malouise
Hi!
Newbie question. I'm working on game animations and making each animation consecutively in Maya's timeline. But when working on animations around/above the 1000 frame mark in the graph editor, it becomes difficult to animate, since when I select a new control, the time slider jumps to the range 0-(whatever animation/playback end frame I set). So even if I've highlighted the animation/playback area 1100-1200, for example, Maya shows frame 0-1200 when I select a new control and I have to zoom in on my current "working area" time after time. And the curves visually look warped and are hard to work with unless I select some frames and press F.
Is there any way to make the graph editor stay in one place? Or is there something I could change in my workflow?
Thanks.
malouise
Found a solution in case someone is wondering the same thing, Graph editor > View > (untick) Auto Frame. It doesn't work ideally imo, as it doesn't take adjust the vertical space anymore (so you still have to zoom in/out to see the whole curve). But it's easier to work with than before.
