Graph editor Keyframes randomly go from the bottom straight to the top of the chart.
m.w.chan
m.w.chan
I'm sure it's something basic but I am a rookie here. The image will show everything, any idea how to fix?
Thank you!
hamsterHamster
Upon baking animation to controls, it might produce such issues that cause gimbal locking, which you probably are experiencing. You'd select all the rotation curves for that object and apply GraphEd > Curves > EulerFilter.
And, if it is HIK rig, then, not sure, but it might be with Quaternion rotations which would make jumps intentionally to keep animation in some range, e.g. -180°..+180°.
If you can afford it, consider changing the rig control's rotation order to the one that causes less gimbal locking, and it is possible, without loosing the animation, with a script, the only thing is it will generate keys every keyframe, which you can clean with some other filters in the Curve menu.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
