Graph Editor Curves Missing
davebaer954
Message 1 of 17
davebaer954
Help!
The curves are missing from my Graph Editor and I can't find how to get them back.
What I've tried so far:
Pressed every button, twice.
Tried every option under the View menu.
Deleted prefs folder. Restarted Maya.
Renamed the Maya user folder. Restarted Maya.
Uninstalled Maya. Reinstalled Maya.
Cursed at my monitor.
Anyone have any ideas?
Replies (16)
Message 2 of 17
kelly_hynes
What version are you using?  Be sure to have to latest update available.  Something similar was logged and fixed in recent updates.
Kelly
Kelly Hynes
Manager, Software QA Engineering
Installation & Licensing forums | Contact product support | Autodesk AREA
Message 3 of 17
davebaer954
I'm using the latest version. 2022.3. I even uninstalled it and reinstalled it to be sure.
Message 4 of 17
kelly_hynes
Is your graph editor docked?
Kelly Hynes
Message 5 of 17
davebaer954
Yes and no. It's the same either way though.
Message 6 of 17
reynosorebeca22
Observer
Observer
It's the same for me, did you manage to find a solution?
Message 7 of 17
davebaer954
Wow. I totally forgot about this.
SOLUTION: Uninstalled and reinstalled Maya.
Message 8 of 17
ls100s
I need an actual solution to this as soon as possible. can someone PLEASE help me? I open my graph editor and all i see is the options for translate, rotate, and scale. I need it for the animation module i am in and school is almost over. i cannot finish my class without my editor. please help!screenshot.jpg
Message 9 of 17
ls100s
I also do not have the time or WIFI to uninstall and reinstall
Message 10 of 17
mspeer
Message 11 of 17
ls100s
Unfortunately, even that did not work.
Message 12 of 17
davebaer954
I've seen other posts about this that says to make sure you've updated your graphics drivers.
Message 13 of 17
ls100s
Yup i tried that. it is the most updated it could go. with only 9 days left of school, i have kind of given up on trying to fix it
Message 14 of 17
davebaer954
I also found this:
Go to Graph Editors > Track View - Curve Editor. Click the Filters button. In the Filters dialog, change the following defaults: Under the "Show" section, check All.
Message 15 of 17
ls100s
Thanks so much. Though that did not do the trick, I let my dad have a crack at it and he had it fixed withing minutes. Again, Thanks!
Message 16 of 17
davebaer954
Great! Glad you got it resolved. Would you mind posting what he did in case someone else comes along with the same issue?
Message 17 of 17
ls100s
Yes.
All my dad did was update the graphics driver. Though it had said it was up to date, and that is why I did not update it myself, my dad forcibly updated it and now my graphs show up just fine. 🙂😀
