Going from Normal to Stepped Mode causes snapping?
899254320
899254320
Community Visitor
Community Visitor
I don't know if snapping is the right descriptor here. But I'm using a referenced model and rig for my class. I've noticed when moving the eyebrow it either goes further down than where I put it, and further up. I have no clue what I'm doing wrong or how to fix it.
All of this is happening on the same frame, so it is not an issue of hidden frames.
stephenkmann
yah, that's kinda  a bug.
 the control for the brow is controlling the jont setup with a set driven key ....
setting the Stepped should only affect the animation curves. but for some reason is affecting the set driven  key animation curve.
