Difficulty with joint setup for a skeleton
COAndyMD7
COAndyMD7
Hello, i'm having some difficulty with my joint setup. I want to use a forearm joint to control the rotation of an adjacent joint, and also be able to control the location of the wrist joint (rotating the wrist joint would move the upper pivot of the forearm joint & move the forearm accordingly). I was able to setup the joints for the forearm but rotating the wrist joint causes the lower forearm joint to move out of position (& wrist rotation doesn't modify the position of the upper forearm). Is this kind of setup possible? How could I go about doing this?
tdHendrix
Hi, I attached a file that might help you get the result you wanted.
For both bones (in my scene I used cylinders) I created a root and an end joint with each having an ik handle. Then I grouped the ik handles and centered the pivot. Then I connected the twist rotation (which is rotateZ in my scene) from the hand to the twist of the ik handle group. After that I parented each mesh under their respective bone.
Greg Hendrix - Senior Technical Animator
LinkedIn : Twitter
COAndyMD7
Wow, thanks for the insight! Still struggling with rigging & this really helped me out. Using your example, I tried templating a full arm ik rig, but I am not sure if it is done correctly. If I key between fk to ik, the mesh moves (even though ik is parented). The ik handle seems to follow, but ends up sticking (without it being keyed). If you don't mind me asking, how can I fix this?
tdHendrix
No problem, I can take a look but the file you posted gives me an error when trying to open it. Can you try saving as a .ma file instead?
LinkedIn : Twitter
COAndyMD7
Thanks much, this one should work. Tried opening up the file and the rotation axis seemed messed up. So I just imported it into a new file, think that should fix things up.
tdHendrix
Your scene was acting kinda weird so I just made a new one to show you an example. I tried to re-create what I think you were trying to do. Hope it helps!
LinkedIn : Twitter
