Can't import .mov file into Maya
(For Maya 2020)
I click (View > Image Plane > Import Movie) then select my .mov file when I get this error in the bottom right corner.
Here is a basic overview
And here is a video showing you my process.
I will give you a cookie if you help me!
hamsterHamster
What codec is used in the mov? Open the Script Editor, there can be other warnings/info regarding the mov you are trying to use.
This is for M2019. Refer to the Help for your Maya version.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
This is what the script editor looks like after I import the .mov file.
Also, I'm not exactly sure how to check the codec of a file.
Alright, I solved the problem again lol. Your reply made me check the video codec in the editor in Blender, and once I changed it the video started working. Thanks for replying again, Hamster.
