07:16 AM
I have a mesh that deforms over a 250 frame animation. I try to export this with alembic so that I can import it into Unreal Engine, but all that is getting exported is the first frame of the animation sequence.
I select the mesh and go to cache>alembic cache> export selection to alembic. From there I have cache time range set to time slider, UV write, write face sets, write visibility, and write UV sets all checked in advanced options, and HDF5 as my file format. I export selection, and what is produced is a dinky little abc file with only the first frame written out. Does anyone know what is happening?
