advanced Skelton error!!
rehab_salem83
Message 1 of 35
rehab_salem83
Hello ,
when I build the rig face in advanced skeleton it completed all the steps except the lips, this error message appears:
Documents/maya/2020/scripts/AdvancedSkeleton5/AdvancedSkeleton5.mel line 21999: No object matches name: lowerLipJoint15
any help please??
Replies (34)
Message 21 of 35
ashutosh_chaudhary_cse_2020
Community Visitor
Community Visitor
same problem
Message 22 of 35
Community Visitor
Community Visitor
after select vertices what can i do
Message 23 of 35
himinglaeva47
Are you having issues setting up the lips? Is so use multi component mode in tools pallet, select your preferred edges around the lips, select verts at corners of the mouth, then build the lips.
Message 24 of 35
rehab_salem83
hello dear,
 when you select the edges for lips , go to modeling toolkit at the right in Maya and choose multi component then choose the vertices and edges , so now you can select the vertices of the lips plus the edges .
Note: choose 3 vertices of the lips : the corner and the up middle and the down middle .
Message 25 of 35
wellington_wp
Community Visitor
Community Visitor
Hey everyone, I recently encountered the same error and tried various methods, but it wasn't working.
However, by following these tips, I noticed something: sometimes the issue can be with the mesh itself. Check if there are any vertices or edges that are separated or even duplicated. This may not be immediately apparent, but it can disrupt the loop and cause AdvancedSkeleton to not recognize things properly.
After using 'Merge' on the duplicated vertices, I had to redo some parts, but it worked. Additionally, by following the previously mentioned tips, it should solve the problem
Message 26 of 35
dharmenderTKTDV
Community Visitor
Community Visitor
First Check Face Model Pivot & Mid Edge Check..
Message 27 of 35
addyrawat83
Observer
Observer
A simple solution to this: use non-symmetrical when doing face rig
Message 28 of 35
addyrawat83
Observer
Observer
Message 29 of 35
faromahu
How did you fix the jaw? did you mean in the body rig or something in the face setup happened?
Message 30 of 35
himinglaeva47
it is during the body set up, so try centering the chin joint in rebuilding the skeleton. if that doesn’t work try unbinding, centering the joint, and then rebinding. if you have already done the skinning or weighting duplicate your mesh before unbinding and after you rebind it copy your weights Back on using the duplicate mesh.
Message 31 of 35
gew_arts1
Community Visitor
Community Visitor
I have a similar issue with the lips except my error is with the top lip.
// Error: /AdvancedSkeleton/AdvancedSkeleton.mel line 30488: No object matches name: upperLipJoint6_L
I have tried re selecting the edgeloops plus the multi select and it continues to have the error. I am hoping it doesn't come down to starting over. Any other suggestions?
Message 32 of 35
isendas
Observer
Observer
did you figure this out? I'm having the same issue.
Message 33 of 35
faromahu
OOOO, I didn't try that. What ended up being the case, was that my mesh wasn't symmetrical? Which is odd since I modeled the face with symmetry turned on. Regardless, I set the mesh to assymetrical in the advanced skeleton face options. That pretty much solved it.
Message 34 of 35
faromahu
What helped me was setting the face rig option to assymetrical. It required a few more steps then usual, but I got through it without a hitch!
Message 35 of 35
riddles512514
Hey! That error usually means the lowerLipJoint15 is either missing or wasn't properly created during the lip rig setup. Try going back a step and checking if all lip joints were generated before finalizing the rig. Also, make sure none of the joints were accidentally renamed or deleted—Advanced Skeleton relies heavily on exact naming.
Rigging can feel like solving a puzzle sometimes—frustrating but satisfying. When I need a quick mental break, I jump into a few fun challenges on funriddlesforkids.com—it helps reset the brain without getting off-track!
