Announcements
advanced Skelton error!!
rehab_salem83
Message 1 of 35
rehab_salem83
Hello ,
when I build the rig face in advanced skeleton it completed all the steps except the lips, this error message appears:
Documents/maya/2020/scripts/AdvancedSkeleton5/AdvancedSkeleton5.mel line 21999: No object matches name: lowerLipJoint15
any help please??
Replies (34)
Message 2 of 35
mcw0
That error message is telling you there's no node in your scene with the name "lowerLipJoint15".  I've never used Advanced Skeleton.  But I'm assuming there's a workflow that creates joints.  Somewhere in the process, that joint was not created.  Are you sure you went through all the creation steps correctly?  Or did you inadvertently rename some of the joints?
As a side note, it's bad practice to hardcode names for this very reason.  I'm surprised Advanced Skeleton does this.
Message 3 of 35
rehab_salem83
no i didn't rename any joints , i don't know where's the issue and why in lips step!!
Message 4 of 35
mcw0
Do you have any joints that are named "lowerLipJoint#"?  Do you have joints intended to be used for influences in the lip area?  If so, were those joints created by Advanced Skeleton?
Message 5 of 35
rehab_salem83
Message 6 of 35
mcw0
I've never used Advanced Skeleton.  But from the UI, it looks like you have the option of skipping the lips.  Since you don't have any lip joints, why not just skip that step.  I'm actually surprised there aren't any checks in the build process.  Maybe they are relying on the errors as their check system.
Message 7 of 35
rehab_salem83
yes it's weird …
 thank you for your help and reply
Message 8 of 35
mcw0
Were you able to skip the lips in your build process?
Message 9 of 35
rehab_salem83
no I couldn't skip the lip step , but I figured out where is the issue
it's the selection of edge loop of the upper and lower lips and I fixed it and it finally worked
Message 10 of 35
mcw0
Congratulations! 🙂
Message 11 of 35
kamranmanankhan369
Hi, Can you help me with how you fixed it? Thank you!
Message 12 of 35
kamranmanankhan369
Hi, I am having the same problem. Can you help me with how you fixed the lip issue? Thank you!
Message 13 of 35
rehab_salem83
hello dear,
 when you select the edges for lips , go to modeling toolkit at the right and choose multi component then choose the vertices and edges , so now you can select the vertices of the lips plus the edges .
Note: choose 3 vertices of the lips : the corner and the up middle and the down middle .
Message 14 of 35
preetarts12
Community Visitor
Community Visitor
hi can you please help me with this . i am having the same error even after trying what you have said..
Message 15 of 35
rehab_salem83
Hello
may be you selected the wrong vertices!!
but anyway please check this YouTube link below from the minute: 22:46
this is the steps that i follow to fix the lips issue...
https://www.youtube.com/watch?v=H48xWl2Y5O0
Message 16 of 35
s_uhrin1
Observer
Observer
How did you fix it? I keep getting this error as well: No object matches name: lowerLipJoint12
Message 17 of 35
rehab_salem83
Hi dear,
Message 18 of 35
himinglaeva47
My jaw end wasnt positioned,  something happened there. I reset the jaw end rebuilt the skeleton and that solved it for me.
Message 19 of 35
etenorioAAAJT
Observer
Observer
How you selected the loop of the lips?
you selec vertex and edges form the LipOuter, LipMain and LipInner?
I have the error:
Advance skeleton/AdvancedSkeleton.mel line 25115: More than one object matches name: LipSetup
but when i try to delete the group "LipSetup" (whitch is empty) appears another error :"c
Message 20 of 35
rehab_salem83
choose 3 vertices of the lips : the corner and the up middle and the down middle plus the edge
