Advanced Skeleton Facial Rig Eyeball problem
Hi I'm actually working on a facial rig with advanced skeleton but I'm stuck at the Eyeball part cause it says on Maya that "this will replace the Eyes from the Body-setup" and then a giant eyeball appears. If anyone knows what causes it I would be extremly grateful  !
Lindsey_Robbins
You are supposed to move and scale the eyeball template it pops up to your character's eyeball size and placement.
firefaced
Community Visitor
Community Visitor
 have stuck with the same problem. All you have to do is to go into "DeformationSystem" and find there Eye_R and Eye_L and Jaw_M - delete all of those joints with all it's children. And then you can select Eyeball and Jaw without any problems.
But then you cannot build face rig (((
I tried renaming bones, but still the same problem
julien.besse
Observer
Observer
Have you already built the face and then came back and tried to do it again and it messed the eyes up at the eyeball stage ? It just happened to me and I corrected it by deleting  the build under Face > Build. I started it all again and the giant eyeball issue didn't happen again
firefaced
Community Visitor
Community Visitor
I figured out that you don't have to select an eye to build eyeball, but when you select it makes them huge. So this problem is solved it works. But with a jaw, when you have to select jaw middle point on a face it still makes "The Thing" with a face - it moves all influenced points to 0 coordinates. But renaming in already build body rig - bone - jaw_M - to, for example, jaw_M_body, solves the situation. And everything works fine 8)
Thanks)
m_ferreira9AYE5
Community Visitor
Community Visitor
I just had to unbind skin my eyes and them re bind them, and it works
