Hey guys, I'm looking for best practices advice when doing plate machining. When you are making large 1/4 or 3/8 plate, what is the typical work flow you guys follow? My big issue is with the flatness of the stock. When I Waterjet out a blank I can get .030 bow in the plate. What are the best practices hold the part down to deck the surfaces with a nominal thickness plate. Assume you don't have a good hole pattern that you can csink or cbore
