Solved by Laurens-3DTechDraw. Go to Solution.
A. Whatmough wrote:
CJ wrote:
Ales,
HSMWorks sees the distance between the Job WCS and a coordinate system selected for tool orientation, which will then be applied to G68.2 (assuming the post was set up for G68.2) If the two match, XYZ will all be zero.
Rob,
It's like using multiple offsets to get around a part (G54, G55, G56). However, instead of using up those offsets, you use one offset (G54) and then move the coordinate system incrementally in the program. (If your machine supports G68.2)
CJ wrote:
Yep. It just works in conjunction with a stored center of rotation on the machine.
G68.2 wouldn't be my first choice though. It's an option available in HSMWorks to those who want it.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Rob Lockwood wrote:
While I didnt follow the purpose when this thread initially came about, ive come to understand it much better recently; I'm just not sure why one would want to use it as demonstrated in this thread, though I probably should give the OP a second pass, I'm sure it would make more sense.
If you want to program a 5x part that's relatively agnostic to the machine you want to run it on.. And/or if your workflow requires blocks to be placed somewhat uncontrolled on the table.. Or if you want to do 5x features, for instance on castings, where features need to be accurate relative a physical location on the part which can't be easily accounted for in CAD. I THINK this last instance is what the OP had in mind? Ramble ramble ramble..
Laurens Wijnschenk
3DTechDraw
René for Legend.
Greg Haisley wrote:
I'm with Rob on this one. Maybe I'm a bit too old to understand. I know my machines don't support G68.2.
I program from the center of rotation for the WCS whether 4 axis or 5 axis. The numbers are all over the place relative the the WCS but the parts come out fine. I have also added additional WCS's for different 4th and 5th rotations for allowing the operator to make small adjustments at the machine verses moving the model in the CAD and reposting.
Everybody has there preferred way of getting the job done.
Laurens Wijnschenk
3DTechDraw
René for Legend.
Greg, I have a horizontal tombstone on my vertical VMC and program it as you do with WCS at the center of rotation. Question; how are you adding the additional WCS points and adjusting at the machine? I'm having to resort to running back to adjust in CAD... your method would be ideal and really help.
Greg Haisley wrote:
Nick, you can break up the operations in different jobs with additional unique work offsets for each side that are in the same location as the original but rotated to a different angles for features used on that angle. Posting all these jobs at once the operator will be able to make adjustments for the additional work offsets to move features on those sides relative to features on the original side. I have done this on tight tolerance parts. I too sometimes move the model in CAD, regen and repost. Both ways will work. The additional work offset is user friendly once you understand how it affects the part. Getting to know where the features move relative the the other side is the learning curve. When you look at the model with all jobs highlighted you should see all the work offsets turned in the different directions.
Hope this helps. Good luck.
A. Whatmough wrote:
So, how did we handle this in HSMWorks? It was simple.
I simply activated tool orientation and selected my SolidWorks coordinate system for that orientation.
(I could have also uses Point and orientation and simply selected a face for z to be perpendicular too and a point for my origin point)
@al.whatmough wrote:
To keep this explanation simple we are going to machine 3 lines on perpendicular faces of a 3” square block.
The Feed plane, Retract plane and Clearance plane will all be 1" from each other. To keep the code easy to follow.
@al.whatmough any chance of fixing up the image links in your OP please? It's a valuable post, but all the image links are broken since the migration.
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
