This problem has cropped up before, but I can't open that particular version of *.ipt file. http://forums.autodesk.com/t5/support/turning-inside-grooving-any-example/td-p/6077253
Anyway I keep getting this error: AxialRetractDistance > axialStockHigh
All my clearances are below the bottom of the current stock.
I thought I'd just get that programmed quick so I can go start making the part, but no. HSM apparently has other plans. Frankly the turning package needs a lot of work IMHO.
I'm off to longhand some code...
not great but if you change clearance to reference the retract it seems to at least generate a tool path. But maybe too much clearance and the back side of the tool may rub.
No need to rant, not going to get you any where. ![]()
Hey, just for others looking into this issue, for me it was a simple fix, change your inner diameter to model I'd, my part was turned from solid so stock ID would be 0 hence the axial error.
Best regards
Mike
