trace operation problem !!!
Coras_Alin
Coras_Alin
i can't use trace operation with tool compensation left or right, just center and this cause tool to machine more then it should and it works just the faces machined between them, bellow are the screens... Can somebody give a ideea?
Replies (12)
Laurens-3DTechDraw
I think this has to do with the trace being a 2.5D operation so it doesn't compensate for the ball in the height.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Coras_Alin
the faces between them work, try yourself to see
jeff.walters
Trace will run the center of the tool along your selection. It dose not compensate for the tool. For that you would need to use 3D project.
Jeff Walters
Senior Support Engineer, CAM
Coras_Alin
ok thx for info
kb9ydn
Even if it doesn't do vertical compensation for a ball mill it should still generate a path though right?  In the second picture it's not generating a path at all.
C|
Coras_Alin
i think it's something to do with chaining, becouse the faces between them, left compensation works perfectly and top faces works just center compensation.
jeff.walters
Have you had a look at the log file?
Jeff Walters
Coras_Alin
Now it works , i don't know how but anyway i still can't machine like a pocket, everythink inside of selection and even machine more then it should with the tip of the cutter.
jeff.walters
Im off for the holidays but will take a look at it tomorrow if i can.
Jeff Walters
Laurens-3DTechDraw
That is what we were saying it doesnt compensate for the ball (most notably in height).
Laurens Wijnschenk
3DTechDraw
René for Legend.
jeff.walters
I have attached 2 MP4 files on trace and one Project. You will see that the trace as stated before will not compensate for the tool. It simply runs the center of the tool along the selected path. No if you are using a ¼ tool and you use the left, right, center comp in the operation and the tool won’t fit inside the boundaries then you won’t get a toolpath.
Jeff Walters
Coras_Alin
ok thx  🙂
