tool outside boundary
Message 1 of 23
I have one suggest.
In selection tab, "tool outside boundary" in my opinion is not best solved. Or, You can put new option that tool force milling outside boundary! It means, when we check line, tool work just outside this line, not inside features. Now, when i check this option, tool goes inside and outside this line. From this reason i must draw double check than go to "tool inside boundary"!!!
Best regards
Replies (22)
Message 2 of 23
No "double check", i was made gramatical mistake in previuos post. Need to stay "double sketch".
Message 3 of 23
lenny_1962
@Anonymous wrote:
I have one suggest.
Best regards
@Anonymous
you are over thinking this, it really like cutting a 2D contour, you can make the cutter stay on the left side or the center or to the right side
so for 3D using boundaries, with one boundary (pocket) you are telling the cutter to stop at 3 possible places on the cutter, tangent to the boundary, center of cutter on the boundary or you want it to travel past the boundary a certain amount aka outside of boundary, just like giving a 2D contour a negative stock to leave.
so if you need more control of where you need the cutter to stay within then yes 2 boundaries are needed, I have 2 other CAM softwares that do this exactly the same, so it seems to be a industry standard.
if you would put up a pic or the model with the toolpath in it we can help you more with possible other options to get what you need.
Message 4 of 23
scottmoyse
I agree with @lenny_1962. Although, granted it would be nice to just have to select one boundary contour, then choose an option to take the boundary all the way out to the stock contour, or something to that effect.... but it's not likely that it will be implemented since you can easily end up with a tonne of checkboxes adding behavioural changes like this in the software. And in this case, it's pretty simple to add a rectangle in a sketch, or select the edge of modelled stock etc etc.
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Message 5 of 23
Ok, i can agree with You(both), but not complete.
One question. Please, can You explain me difference between "tool inside boundary" and "tool outside boundary" and why when we check "inside" tool force milling inside, in case "outside" we have different situation?!
I am not new in this software, more than 100 mold tools i am made in HSMWorks.
Offcourse, is not problem for me add rectangle, but i think that is possible put one option for force milling outside  boundary in 3d milling options.
regards
Message 6 of 23
Laurens-3DTechDraw
Currently, there is no option to force to tool to not go inside of a boundary.
(Making an extra solid could help though)
@Rob_Lockwood made a good video on what inside, outside or center mean: https://youtu.be/tz9cSgEdGYk?t=6m2s
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Message 7 of 23
Hello, Mr. Laurens,
Yes, i know that now we have not option for force milling outside boundary. This is just my suggest for some new realise of Software.
regards
Message 8 of 23
scottmoyse
You can create a post on the ideastation and see how many people vote for it. Then maybe it will get implemented.
Scott Moyse
Message 9 of 23
lenny_1962
@Anonymous
Easiest way to explain this is......................... It's where the tool "STOPS"  that's all it means. nothing more, nothing less, sorry.
What you are really asking for is is more of a which side of the boundary do you want to start from, like a 2D contour using the reverse function. correct?
Then again you might still want to control where the tool stops from the other direction. correct?
Which means the inside-center-outside would still need to work the same, correct?
So here is my take on what "TOOL OUTSIDE OF BOUNDARY" means, it is so you can blend onto other faces so as not to create any hard lines of where one path ends to another already cut, making a clean transition. Sometimes good, sometimes bad if your machine grows there still might be an edge\step created.
As @scottmoyse suggested make an enhancement request for SIDE OF BOUNDARY to start from not by changing what it the current norm for tool outside of boundary.
JMO
Message 10 of 23
Rob_Lockwood
I'd also add, it's equally annoying that we can have multiple boundaries, but must select a single option (inside/center/outside) that applies to ALL boundaries, rather than being able to apply that setting to each. It's a fairly common that you want to mix/match, and it effectively forces geometry construction.. It's not a huge issue, but the idealist in me see's opportunity.
Rob Lockwood
Maker of all the things.
| Oculus | | Locked Tool | | Instagram |
Message 11 of 23
lenny_1962
Now that's one a can totally jump on board for!
Message 12 of 23
I will agree with You (all) in moment when someone exsplain me matematical and geometric difference between inside/outside boundaries. I think, no difference. This is not philosophy, this is just command to tool that must go inside or outside boundaries. It is not nuclear fusion.
Example, i have one close chain and this is my boundaries. I want remove material whit rough operation (3d adaptive or pocket), in some cases i need that tool goes inside the boundaries , and this is correct, but in some cases i want work outside this close chain. In this moment, i can not do this with one of the option (inside/centar/outside), than i must add rectangle or circle or any closed chain that i can work AGAIN inside this new boundary. WHY WE HAVE OPTIONS (outside) WHICH THEY DO NOT USE???
Message 13 of 23
Laurens-3DTechDraw
@Anonymous
Outside works. It just means something else than you expected.
So you would want another boundary option that excludes the selected boundary from the path. That would still need the inside/center/outside of the boundary. Just changes if it's included or excluded for the toolpath.
Laurens Wijnschenk
3DTechDraw
René for Legend.
Message 14 of 23
lenny_1962
sorry you don't get it.
again the function of the inside\center\outside of boundary is for stopping the tool not telling it the side of the boundary you want to cut!!
this is an industry standard for CAM for tool containment. been using this in other CAM software for 10 plus years so it is great the HSM follows that standard.
Message 15 of 23
narzinskin
I use this in my training as it is easier than putting into words.2017-10-12_11-10-20.jpg
Message 16 of 23
Gents,
I submitted this about a year ago in the idea station. Please vote it up...
https://forums.autodesk.com/t5/hsm-ideas/have-the-ability-to-set-different-tool-containment-types-fo...
Message 17 of 23
narzinskin
I voted on this back when you created it, but this is in the works and pretty much describes the Blend operation as i understand it.
Message 18 of 23
scottmoyse
Agreed! It's fine the way it is.
Scott Moyse
Message 19 of 23
lenny_1962
@Anonymous wrote:
Gents,
https://forums.autodesk.com/t5/hsm-ideas/have-the-ability-to-set-different-tool-containment-types-for/idi-p/6553370
nope
Message 20 of 23
Laurens-3DTechDraw
Well no. Blend just is surface driven. And will cut the selected surface. And make sure it doesn't go through other surfaces. But there is no boundary containment for that toolpath.
Laurens Wijnschenk
3DTechDraw
René for Legend.
