Surfacing with this tool?
scottmoyse
Mentor Mentor
Message 1 of 20
scottmoyse
Hey guys,
Does anyone know of a CAM package that can generate an accurate 3D surface toolpath using this kind of tool?
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Replies (19)
Message 2 of 20
Laurens-3DTechDraw
scottmoyse wrote:
Hey guys,
Hypermill I believe.
https://www.youtube.com/watch?v=tkvVUHV-8MA
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
Found out the hard way is the best way to win.
Message 3 of 20
scottmoyse
Yup. That's very close.
Scott Moyse
Message 4 of 20
The most simple tools are grinded.
Most incredible is the Numroto software package for machining special tools: http://www.num.com/web/num.nsf/id/3d-simulation-en
Message 5 of 20
scottmoyse
I think you've misunderstood me. I wasn't asking about software that will allow the user to program the toolpaths to grind the tool, but rather use the tool itself. In any case, that's interesting information you've supplied.
Scott Moyse
Message 6 of 20
Steinwerks
If I'm not mistaken that's a large radius small diameter two flute end mill, yes? No double radius or form diameter specs?
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 7 of 20
scottmoyse
If I understand you correctly yes... There's a G0 surface transition condition between the radius on the end of the tool and the side of the tool. It's a hard edge. I don't think HSM (and most other CAM systems) can allow for that when calculating surfacing toolpaths.
Scott Moyse
Message 8 of 20
Ahhh, ok! barrel tools, and other like this one.
Isn't it the same as using a a ball mill tool, with thinner shank and narrower Slope angle?
Message 9 of 20
scottmoyse
No because all the HSM tool definitions maintain tangency with the tip radius.
Scott Moyse
Message 10 of 20
Rob_Lockwood
AFAIK, hypermill and NX are two, but i've not actually tested in either yet. I feel like hypermill apps guy actually showed me this, but I don't remember anymore.
Rob Lockwood
Maker of all the things.
| Oculus | | Locked Tool | | Instagram |
Message 11 of 20
mwhitten123
If it's just a large radius at the end of the tool, Mastercam can do this as long as it's only using the radius or just side milling with the periphery. You can create a custom tool shape and calculate to a ball shape. The custom tool will be used for backplot(simulate) and verify(solid simulate) and the specified ball mill will be used for the toolpath calcs. This at least makes for a very accurate verify.
I am hoping that HSM can do the above soon. Basically, we need to be able to define a custom tool shape and calc to a standard shape.
Michael Whitten
Selway Machine Tool
CAM Support
[email protected]
Message 12 of 20
Laurens-3DTechDraw
That is what happens with the form tools in HSMWorks. It calculates as if it was a flat endmill.
I would just say that at least every inserted mill in the Kennametal, Iscar and Sandvik catalog should be supported out of the box. These kinds of solid carbide tools would be nice and neccesarry in the future. But the form mill with choosing the kind of tool it should base the calculations on is a good one since a flat end mill will not work in many cases.
Laurens Wijnschenk
3DTechDraw
Message 13 of 20
NX yes but with more 5 axis mills available form tools are becoming old school.
Message 14 of 20
Laurens-3DTechDraw
Actually they are reinvented for 5-axis. Like the barrel tools:
https://www.youtube.com/watch?v=R0-2ChNKM_w
https://youtu.be/bfAXFGGJuEc?t=2m25s
Laurens Wijnschenk
3DTechDraw
Message 15 of 20
Different type of form tool. Side vs bottom. Bottom radius tools have the same issue as ball nose tools. No surface feed at the tip. Better to use a mill with a rad and tilt into the cut. Barrel radius tools are great though as the allow the axial step down to be greater while still keeping the cusp between passes low. Nothing new though. Did that 10 years ago. Also the impeller in the vidio is pretty tame.
Message 16 of 20
Laurens-3DTechDraw
True, but on the other hand make it with Fusion 360. I mean there is a lot of work that needs to be done before that is possible in a way that you can actually make a buck.
Well your said form tools are becoming old school, well some types are, some aren't.
And high feed cutters are getting more used which means it would be really nice to have them simulated and programmed correctly.
Laurens Wijnschenk
3DTechDraw
Message 17 of 20
scottmoyse
No I would want the toolpath to be able to transition the cutting from the tip to the side where needed. However, like Laurens said, the approach Mastercam is taking would help, since we can't assign a standard tool profile to use for the calculation. So you raise a valid point, but it's not what I was after.
I don't consider the geometry of that tool to be complex, so it's not like the kernel team have to support all custom geometry, just all the modern standard profiles. Carbide or insert.
The main reason I started this thread was to find out how many other systems can handle it properly. NX & Hypermill seem to be the only ones so far. Mastercam's solution is a compromised workaround.
Cheers guys
Scott Moyse
Message 18 of 20
mwhitten123
Hello Scott,
I fully agree with your comments - The main point is that we need improvements in Custom Shaped and "non-standard" types of tool support. If we can at least Solid Simulate(verify) to a custom shaped tool, we would be much further ahead than where we are now.
Michael Whitten
Selway Machine Tool
CAM Support
[email protected]
Message 19 of 20
scottmoyse
Well we can do that now. But I suspect you mean alongside specifying a standard tool to use for the calculation.
Scott Moyse
Message 20 of 20
mwhitten123
oh...Yes, that is what I mean
Michael Whitten
Selway Machine Tool
CAM Support
[email protected]
