I am currently using fusion to program a 5 axis bridge saw for milling 3axis. Here below are a few pictures of the results using only a stone milling cutter.
The process takes much time, so the idea is to cut parallel slots using the circular saw with 20mm spacing between each pass. I would like the saw to plunge only 2-3cm at a time and also follow the profile of the model once reaching the final step downs.
Im having a specially hard time following the contour of a sculpted 3d model that has many complex shapes and vertices.
How would one proceed using fusion cam? Any tip or suggestion is greatly appreciated.
Kind regards,
Rajis
