HSMWorks has been highly optimized for multi-CPU/core PCs. But if you run HSMWorks on old hardware you might not be benefiting fully from the potential. If you find that you are waiting for a long time for the toolpath to generate you can test if your PC is out of date. To do so you just need to run our performance testing utility available at http://www.hsmworks.com/performance/.
You can compare ratings for different PC generated using the same version of the performance utility. You CANNOT compare ratings across different versions of the utility. New PCs should have a rating of 350 or above when using the r21323 version.
The following rating was generated for a PC with an Intel i5-760 CPU (with 4 cores).
René Fonseca
Software Architect
