I know this is way off-topic ::) even for "General Discussions", but i'm a little desperate at this point.
I'm heaving a problem with Electronic Gear Ration (numerator/denominator) on a LS Mecapion Servo, 1Kw AC Servo Motor, 3000 Nominal RPM, 19 bit's Multi-Turn Absoulute Encode's, Motor's are identical on all axis.
Machine Specs:
- Z axis, 800W Servo (with break), Ball Screw 10mm Pitch 16mm Diameter, Belt and Pulley 1:3 ratio.
- X axis, 1Kw Servo, Rack & Pinion Modul 1.5, 4,7124mm Pitch, Z20, Belt and Pulley 1:3 ratio.
- Y axis, 1Kw Servo, Rack & Pinion Modul 1.5, 4,7124mm Pitch, Z20, Belt and Pulley 1:3 ratio. Gentry 2 Servo motor's
I;m attaching a part of servo manual regarding electronic gear. I don't know how to calculate the numerator and denominator from this table.
If someone can explain to me how to apply this table, I'l be very happy!
Tx
