Machining Discussions
Inventor HSM 2017
65 REPLIES 65
Message 1 of 66
makko74
3737 Views, 65 Replies
Inventor HSM 2017
the new Serial/Key for Inventor HSM Pro 2017 is now online in the autodesk account but when and where can i download it?
/Mario
InfoInventor CAM(Ultimate) user --- Inventor Professional 2021.2 + Inventor CAM Ultimate 8.1.2.21785
65 REPLIES 65
Message 61 of 66
@jorgengyselinck wrote:
creating toolpath in inventor hsm  is going verry slow .
And every time I select a mill option i need to wait verry long.
it there a way to use my gpu for acceleration ?
system:
amd fx8350
16 gb ram
nvidia gtx 780
samsung evo ssd
That really shouldn't be needed.
It should run pretty smooth on that pc.
Could you make a screencast(video) so we can see when exactly it hang/takes long?
Can you also check if there is a high CPU use at that moment?
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Message 62 of 66
Thanks for your reply
here you can find the video
https://drive.google.com/open?id=0B1ZZoJ73bf_2ZE5kaVlscmV2X3M
jorgen
Message 63 of 66
The easiest thing to spot is that your harddrive/ssd is working at 100%.
Which would be weird for an SSD.
Pretty sure that is your problem. Is Inventor installed on a separate hard disk? Or is the file located there?
Laurens Wijnschenk
3DTechDraw
René for Legend.
Message 64 of 66
Dear
no inventor was not running at the 100 procent drive that is my Hdd it was copying at that moment.
inventor is on the ssd en same problem without copy
jorgen
Message 65 of 66
Running the same CPU at home, also 16GB of RAM, and don't have any issues with slow toolpath generation, also have Inventor, Fusion, and HSMWorks all on SSD along with the OS.
I would avoid heavy hard drive operations while doing anything else though to start with and see if that is what was causing the processing bottleneck.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 66 of 66
Dear
Do you want to test one thing for my i posted my file on google drive.
Can you test whit my file what i did in the video ?
thanks a lot
jorgen
