HSM tool path problem on chamfers
vedadave
vedadave
Autodesk Inventor HSM pro 2015
Windows 7 x64
Operation: 2D Circular, Using a ballnose endmill tool to cut chamfers on multiple holes feature tops.
Problem: If 'Hole Bottom' is selected as the bottom height then the tool will not move low enough to cut the full chamfer.
              If 'Hole Bottom - offset' is selected then only one tool path is generated - on the first hole.
              If 'Model Bottom' or other height is selected then no tool paths are generated.
Questions:
1. What is the preferred way to cut such a chamfer if I don't have a correctly sized chamfer tool?
2. Is there a work-around?
Replies (8)
Laurens-3DTechDraw
Using 3D Contour?
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
hansun_zhu
For the failed cases you got, it could be related with the tool size or offset value based on the hole diameter, so could you please try -
1. Use a smaller tool or reduce the offset if possible?
2. Or try to do the chamfer on each hole individually to see whether it can work fine?
3. Or to use 2D Contour with checking "multiple depth" (specify the related taper angle) and the desired offset in bottom height
If you can let us know the tool diameter and the each hole's diameter, it could be better for us to know what the problem is.
Hansun
Laurens-3DTechDraw
Hansun
I'm baffled with this response. Since when do 2D operations compensate for the endmill's radius. He is using a bullnose/ballnose he said. And running Inventor HSM Pro. Go 3D!! Easier to program with better results.
Laurens Wijnschenk
3DTechDraw
René for Legend.
jeff.walters
If you only have 2D then 2D Contour with multiple depths can work. If you have 3D then you will most likely get better results with 3D contour or maybe even a 3D spiral. The advantage of the 3D toolpaths is that the tool will stay in contact with the part more.
Jeff Walters
Senior Support Engineer, CAM
vedadave
I tried 3D Contour and it works ok. I had to calculate the bottom depth based on my 3/8" tool and the depth of the chamfer though. Otherwise the the tool path goes all the way to the hole bottom.
2D Circular with a 45 degree chamfer tool works faster but I only have a metric tool and no collet for it.
lenny_1962
then make an adapter for it, do that all the time, lathe, drill hole, then drill for set screw, then use that in a collet.
Laurens-3DTechDraw
You can just select the bottom of the chamfer as your bottom value and give a little negative offset value. It's even quicker than the 2D version especially when you don't give in a boundary but just use the check surface, select the chamfer and turn on touch surface.
Laurens Wijnschenk
3DTechDraw
René for Legend.
17asleep
You do realize that non-metric collets can be used on metric shanked tools?
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
