How to create special threads
novly.abdurohman
novly.abdurohman
Hi All...
Please advice, i will be creating special threads 5/16-24 Tpi. I can't find out the type of threads from library.
Please find attached picture sample tools that I used
Appreciate any kind help and support
Regards
Nov
fredsi
Not quite sure I understand what you're looking for, but....the 5/16-24 thread is located in the ANSI Unified Thread category (at least it is on my installation of Inventor).
BTW, if you want to add any thread that is not available in the standards, just edit the Excel (.xls) files located in C:-user-Public-Documents-Autodeak-Inventor 20xx-Design Data-XLS-language folder.
Fred
Laurens-3DTechDraw
Fred
Right it's an UNF(ASME B1.1) thread.
It's just straight no taper.
And you know that that tool isn't suited for the job right?
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
jeff.walters
Just a side note but you done need to model the thread in order to cut it. All you need is the correct diameter hole.
Jeff Walters
Senior Support Engineer, CAM
novly.abdurohman
OK thanks, Jeff..
Cheers
