How to create a Face Grooving with a curved profile
Olina0212
Olina0212
I want to make a Face Grooving in lathes with Turning InventorCAM
Is there any way to create it?
Please help me
aewrmc
Is something like this what you are after?
Olina0212
If the gap is large the story is simple, however if the gap size is 2mm, the Groove tool cannot be used for machining because the smallest tool size is 3mm.
So I came up with one like this, but it doesn't work as intended.
aewrmc
You won't be able to machine the grove the the trapezoidal shape tool? You'll need a tool similar to the one linked below?
Or, if you have live tooling in the lathe you can use a ball endmill?
https://www.iscar.com/eCatalog/Family.aspx?fnum=4491&mapp=TG&app=54&GFSTYP=M
Olina0212
Many thanks for your support
It's so helpful
There are so many stopping tools that I don't know yet
Can you share where you usually look for tool types of stuff?
aewrmc
I normally use the ones below for my purposes, it depends on your location and what is readily accessible.
https://www.iscar.com/index.aspx/countryid/1
https://www.sandvik.coromant.com/en-gb/products/pages/tools.aspx
https://www.walter-tools.com/en-gb/pages/default.aspx
Olina0212
Thanks again for your sharing
