What is the best way to program a high feed endmill to cut a slot?
Some more info about your application would be helpful. Although, if the cutter is smaller than the slot (but greater than half the width) then use a helical path for best efficiency.
2D-Contour -> Select one side of the Slot; no extension for the start or end -> no compensation, both ways -> no lead in/out, ramping
