I am fairly new to CAM, I have created a Eyewear mold, I would like to create an operation to mill the pocket where the glasses will be inserted, can someone offer some help? I have attached the Part.
@Anonymous
Your stock had issues because it consisted of many triangular faces, mainly because it was imported from mesh geometry and needed to be repaired.
Anyway, I've recreated another stock body and it is fixed now.
In your first (pocket) operation you have to include rest machining from setup stock.
For your finishing operation it is better to choose for example 3D contour instead of Trace operation which is 2D op.
Be advised that those operations that I made are just for example.
Please check the attached part.
Ivan Stanojevic
