Inventor HSM and Fusion 360 CAM trainer and postprocessor builder in the Netherlands and Belgium.
Arjan wrote:
Hi Joe,
If you use 0 and 90 degrees it could be mostly a postprocessor thing. I worked with an old Maho machine with Heidenhain control, and we added a post configuration option "use horizontal yes/no". On this machine the coordinate system changed from tool pointing in Z directing to tool pointing in Y direction on tilting the head. If your machine is the same, it needs to be done in the post.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Hey @JoeBarnes4076 did you ever get anywhere with doing this?
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
