Machining Discussions
Can I setup the program to reduce speed when the machine is cutting at conners?
3 REPLIES 3
flightyan
635 Views, 3 Replies
Good morning
I'm now fabricating Pure Tungsten which is known as the hardest material. Well, I could able to machine with some simple conditions, however the biggest problem is that the tool wears too fast.
I hear some screech when the machine is just cutting around the corner of the piece, I think I could make it better by reducing the speed of the corner. (ex : the default speed is F1000 and it becomes f300 when cutting corner)
But I don't know how to do this, Do you guys have any idea or experiences about this? thank you.
3 REPLIES 3
arjanX7QEP
in reply to: flightyan
You can use Feed Optimization. I never used it, but this controls feed at corners.
FTKnur
in reply to: arjanX7QEP
And best of all ... we have had a naming error for YEARS. "Just inner corners" should be "just in corners". This tick should actually always be deactivated, then it also reduces the feed by "X" mm before the corner.
Unfortunately, ADSK has never managed to ensure that the feed rate is not reduced for an outside corner ... only playing around with the values helps.
flightyan
Thank you for your great answer, I will let you know the result shortly after test cut. Have a nice day!
