Machining Discussions
3d adaptive clearing clearing leaving stock over opening
1 REPLY 1
ampetty
658 Views, 1 Reply
I'm trying to use 3D adaptive clearing as the first process of a setup with rest machining stock from a previous setup. There is an opening that was cut from the other side of the stock and adaptive isn't removing all of the stock. There are no model surfaces selected that would cause it to leave stock here. How do I stop this from hapenning?
Thank you,
Austin
1 REPLY 1
ampetty
in reply to: ampetty
I discovered the problem was I selected the whole manufacturing model as the setup rather than the main body, so all manufacturing model surfaces were included instead of only the ones selected.
