Message 1 of 16
2D Contour, Multiple Depths,
05:44 AM
I'm cutting using 2D Contour and multiple depths of cut.
I remove lead in and lead out
Use the ramp lead in only.
The ramp angle is by default 2 degrees.
I change it 20 degrees
(for some reason the 20 degrees won't change unless I change the ramp clearance height from the default 0.1 to 0.05, BUT that's besides the point)
The issue is the first depth of cut uses the specified 20 degrees BUT subsequent depths of cut use a long ramp that seems to be 50% of the chosen contour length (see picture). There is no parameter to modify for subsequent depths of cut. I assume the 20 degree ramp angle should be used for all depths of cut.
To elaborate, the lead in length on the second depth of cut for a small part with a 4" perimeter would be approximately 2" and a larger part with a 20" perimeter would have a 10" lead in (too much and too slow).
