Sketch a curve, and have toolpath follow
rsalasidis
Message 1 of 13
rsalasidis
In Pro/E skethed curves (2D or 3D) were used for defining a unique cut path for a tool. The tool could be made to follow it. In addition they could be used for engraving etc. Does a similar funtionality exist in Inventor HSM.
Replies (12)
Message 2 of 13
Rob_Lockwood
The 2D function 'Trace' will allow the tool tip to follow a 2D or 3D curve.
Rob Lockwood
Maker of all the things.
| Oculus | | Locked Tool | | Instagram |
Message 3 of 13
rsalasidis
Thanks. Will this work with imported DXF or DWG files, and can I select all the curves with a window?
Message 4 of 13
Laurens-3DTechDraw
Are you using HSMWorks or Inventor HSM?
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Message 5 of 13
rsalasidis
Using the Inventor HSM 2016 Trial
Message 6 of 13
Rob_Lockwood
Not sure in inventor, i'm an HSMWorks user. In Solidworks/HSMWorks, you'd just bring your DXF/DWG in as a sketch/3d sketch and then directly select the sketch in the operation - even easier than selecting the sketches with a drag/select window..
Rob Lockwood
Message 7 of 13
bobvdd
We don't have window selection for selecting geometry in Inventor HSM, so you will have to select each separate sketch loop individually. For open sketch loops, you might need to select the loop twice to get control over the exact start and end segment of the open loop. Use the mini-toolbar to switch between open and closed loops if necessary.
Here is a picture of that mini-toolbar and the more granular selection process (dark blue segments are the segments that I selected as start and end, the cyan colored segments between start and end are automatically included in the selection set without having to click these).
Use the CTRL key to de-select previously selected line segments.
Bob
Bob Van der Donck
Principal UX designer DMG group
Message 8 of 13
jeff.walters
If you want to select everything in the sketch when you’re on the geometry tab with the curve selection button heighted, all you have to do is change from the CAM to Model select the sketch you want to trace, go back to CAM and everything in the sketch will be selected. The order of selection is left up to how the sketch was done but for a lot of entities it’s a quick way of doing it.
Jeff Walters
Senior Support Engineer, CAM
Message 9 of 13
bobvdd
Thanks Jeff. Forgot all about that. Much easier than selecting individual sketch elements.
Bob
Bob Van der Donck
Message 10 of 13
JoeBarnes4076
Does that work for an assembly level sketch?
Message 11 of 13
bobvdd
No. You would need to create an extra empty part that contains the sketches in order to be able to select them in CAM . If the DXF or the DWG contains 3D sketches, you would have to do this anyway because Inventor does not allow 3D sketches in an assembly to start with.
Bob
Bob Van der Donck
Message 12 of 13
scottmoyse
Arggghhh. One day. Maybe. Inventor is the only HSM product you can't do that in.
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Message 13 of 13
In Fusion 360 I was able to preselect the sketch prior to going into the geometry selection of the trace toolpath and this worked to select all line segments and I probably have 1000 - 1500 line segments in a crazy pattern. Fusion did a great job of setting direction so that each longer segment made up of smaller segments was all going the same direction.
