Sharing Tool Libraries in a Project
Is it possible to share tool libraries across a project?
I have turned on Cloud libraries and created a new library, but I'm the only one who can see it in the project.
Is it visible anywhere in A360?
jeff.walters
They are stored on your A360 drive. They are also saved on your local machine.
PC: C:\Users\USER_NAME\AppData\Local\Autodesk\Autodesk Sync\Cloud\A360_DRIVE_NAME\CAMTools
MAC: /Users/ USER_NAME /Library/Application Support/Autodesk/CAM360/libraries/Local
Jeff Walters
Senior Support Engineer, CAM
Where can I find them in A360?
Also- can other members of the project see the library?
jeff.walters
The easiest way I know of is to go to the blue shell looking icon on your task bar, right click and select Launch A360 web (or https://myhub.autodesk360.com/g/projects/drive/data/root).
Once there depending on your view when you hover on the CAMtools folder you will see a share icon.
Select it and enter the email address (or addresses) you want to share the folder with.
If you go into the CAMtools folder you can share the separate tool libraries (.json) file as well
Jeff Walters
