Polygon turning/ Milling Mazak t plus
IS there a polygon turning option in HSM Inventor?
I am looking to run a part which I an use the polygon turning mode on a MAzak SQT18 with T-Plus control.
I would like to run the polygon milling mode to cut a hex. IS this possible in HSM?
Laurens-3DTechDraw
Simple answer is no.
I'm not aware of any CAM system actually doing this.(They might be, but I've not seen anything about it yet.)
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Rob_Lockwood
What i've seen done, in NX, but it's probably common elsewhere too.  is making a normal to centerline 4-axis milling toolpath using a similar cross sectioned tool, and transforming that toolpath for turning. I don't think HSMWorks has the tools available to pull this off, even in a fairly hacked together manner.
Rob Lockwood
Maker of all the things.
| Oculus | | Locked Tool | | Instagram |
Laurens-3DTechDraw
But even that is kind of a hack right?
Laurens Wijnschenk
3DTechDraw
René for Legend.
Rob_Lockwood
Yep! That was essentially my point; even where it does exist, its pretty cobbled together. There might be some places where it's implemented better, but it's such a fringe use case operation that I'd bet it's usually less resource intensive to just solve on a per-application basis.
Rob Lockwood
