Is there a better way?
Message 1 of 18
my company has access to f360.  I am attempting to cut a radius in a series of parts.  I have all of the radiuses lined up, and they are all the same.  Is there any way to bridge the radiuses so that it doesnt cut just one part at a time?
Replies (17)
Message 2 of 18
Rob_Lockwood
make a surface that extends across all of the rads and use that to define your model for those operations, rather than the models themselves..
Rob Lockwood
Maker of all the things.
| Oculus | | Locked Tool | | Instagram |
Message 3 of 18
I have given that some thought, but i haven't a clue on how to create a surface to do that, especially in Inventor assembly mode, where i do most of my cam work (all but 3d), but especially in fusion 360.  Ill play around with it, but any help would be appreciated.
Message 4 of 18
Steinwerks
Go into Patch mode, under Create, select Extrude, and extrude your first part's right edge out to the far right edge of your last part. It should create a new body that you can hide for your other operations. Simple and fast.
See the bodies lightbulbs on the left.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 5 of 18
scottmoyse
Yeah that would be because the Inventor Assembly mode sucks for CAM related model changes. Solidworks is much better in that area. I'd love to be able to say that the Inventor team are working on rectifying that, but I don't think they are. Maybe the CAM team have other plans?
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Message 6 of 18
Steinwerks
Can't believe I never even got an acknowledgement...  :-X
Neal Stein
Find me on:
Message 7 of 18
scottmoyse
The OP hasn't replied since you posted that. Your solution for F360 is exactly how it should be done.
Scott Moyse
Message 8 of 18
Steinwerks
I just hate when OPs disappear! No good feedback. Happens on Practical Machinist as well sometimes and then no one knows how operations turned out.
I couldn't think of a better way to do what was asked. Glad to see someone seconds the method, as I want to know when there are better alternatives, too!
Neal Stein
Find me on:
Message 9 of 18
Laurens-3DTechDraw
Since the fragment extension distance doesn't work there is no other way indeed.
Also something funny with the steep area's when you select another part like I did in the attached part.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Message 10 of 18
Steinwerks
Thinking of getting off of SW or something?  😉
Neal Stein
Find me on:
Message 11 of 18
Laurens-3DTechDraw
Yes,
Hardcore HSMWorks user here, so I usually have some tricks up my sleeve. 😉
Laurens Wijnschenk
3DTechDraw
René for Legend.
Message 12 of 18
Steinwerks
I did get the extension to work, but one would have to create extra geometry to keep the path contained between parts with extra avoid surfaces. I think the way I did it is still easiest.
Neal Stein
Find me on:
Message 13 of 18
Laurens-3DTechDraw
Actually when you could make the extension long enough it would just continue into the next part. You could make a sketch to contain it but wouldn't be necessary I guess.
Laurens Wijnschenk
3DTechDraw
René for Legend.
Message 14 of 18
mfeathers
While not exactly the same N.Stein... your solution did help give me a way to clean up some of my tool paths on an object I was working on in Inventor.
Where I was previously doing something like 3 different tool paths (with different parameters throughout), I now have 1 clean tool path that accomplishes the same thing by using a modified copy of the original solid.
Message 15 of 18
Steinwerks
Cool! Glad something I did helped you!
Neal Stein
Find me on:
Message 16 of 18
Steinwerks
Yes that's what he wanted in the first place, I thought that's what we were talking about.
Here's what I got, and after adding the avoid faces of the other three parts. It "works" but you can see how it spills over outside the parts and why I said one would have to contain it somehow. Might as well extrude the first part and then hide it afterwards.
If there are parameters to keep it in line, do share! 😄
Neal Stein
Find me on:
Message 17 of 18
Thanks, It does work.
My bad for the DELAYED responce.  Kinda been a little busy, and I dont always have time to jump on here.
I was just thinkin that there was a box that i could click to make it bridge the parts.  just wishfull thinkin.
Message 18 of 18
Steinwerks
You're welcome! I'm glad to help any way I can. I still feel I'm pretty green to HSM* but I like to contribute when I can, and I feel I'm one of the longer Fusion CAM users here. I don't go to the Fusion forums, as they're horrible to navigate.
Not a big deal honestly. I just spend a lot of time on here and Practical Machinist, including a lot of off time (I did the example at home) and so I have a skewed sense of reply time.
I can think of a TON of things I wish I had a box for!  ;D
Neal Stein
Find me on:
