To whom it may concern,
I am running the lighting analysis through the Insight 360. But, I realized that the Lighting Analysis button (or option) that was previously displayed in the LIGHTING icon in the Insight 360 is gone. (This opened the results from the LEED analysis and applied them to the 3D model). Please, could you tell me where did this option move to?
Kind regards,
José Luis Bermúdez Alcocer, Ph.D., M.Arch., B.Arch.
Solved by mstein7484. Go to Solution.
Hi @beralco
With the new version of the Lighting Analysis tool one icon functions to both create a new analyses, and generate the reports of the completed analyses. The completed Analyses will appear on the drop-down of the Lighting Analysis dialog window. To view the results, select the analysis from the drop-down list. It will say "Generate Results" next to the name. Click "Go." This will not rerun the analysis and you will not be charged any cloud credits, it will just generate the results for you to view in the Revit model.
Let us know if you have more questions on this topic, otherwise please accept as a solution so that others can benefit from this information.
Dear Ms. Stein,
Thank you for your time and help!
Kind regards,
You are very welcome!
I have the same problem and I do not see a dropdown list when I hover my cursor over the "Lighting" icon.
Is there a plug-in that I might be missing?
Thank you,
Eduardo
Hi @jmission
The Lighting icon no longer has a drop-down menu for generating existing analysis results. Click on the icon to launch Lighting Analysis. In the dialog window you'll see the options to either start a new analysis, or generate the results from a previous analysis. The names of all previous analyses will appear on the dropdown list.
